Nuts and Bolts
  • Nuts and Bolts
    I guess I'll post this here
    There is already a reference for sizes here: http://z31.com/wiki/doku.php?id=reso...nuts-and-bolts
    I wanted to add some more here for those looking for it. I recently pulled the motor and some body parts, so I'l add more as soon as I find the paper that I wrote them down on...
    Body Trim and Accessories:
    84-86 Headlight:
    Metal retainer (holds 6054 headlight in): 4x per headlight, M4x8
    Black trim piece (goes over headlight and fog on each side): 2x per side, M5x8
    That's the page I started ages ago elsewhere, glad to see it was saved... and yes it needs updates
    Flywheel-to-crank M10x1.0 -- I believe 30mm long
    Pressure plate-to-flywheel M8x1.25 -- 20mm long
      Yeah, I got quite tired of:
      "Welcome to Nissan! What Part can I help you find?
      (pulls up diagram and I point to screw)
      Oh that one right there? No, we don't have any in stock. We can order it for you!
      (I ask about size) Oh, no, we don't have that information available.
      How many do you need? Just one? Ok! Well, they are $1.80 each, but you have to order 20."
      I like access to the sizes so I can go to the hardware store up the road and get the screw for $0.05. Like most Z31 owners, I'm not in the best financial shape either!
        R200 pinion nut = M20x1.5 prevailing torque nut
        And someone needs to check the crank pulley bolts to be sure, the one I have is: M12x1.25x80mm and uses a fat washer 35mm OD, 8mm thick
          Additionally:
          http://www.garymolitor.com/300zx/par...ts_list-01.htm
            Glad to see someone has photographic proof that I used to contribute to the Z31 world...
              This is great info, can we get thies charts in the reference section
                Still can't seem to find the size of the turbo elbow flange to downpipe studs and nuts.
                http://z31performance.com/showthread...2-2-(-now-NA2T
                My build thread (:
                  Pressure plate bolts: m8x1.25 17mm long (4mm shoulder) JIS flange head
                  Flywheel bolts: m10x1.0 24mm long (3mm shoulder) JIS flange head
