I suspect that my battery is weak but I never saw this (living north Canada I know how behave a dead battery!)
I put the key to ON position, everything is normal, start the car, nothing but a weir click (not the usual starter selenoid click (or may be the selenoid + something else)).
Then no power at all, no door beep/radio etc.. Remove the key, put it back, nothing. SO I jumped out to unhook the battery suspecting a complete battery short circuit but everything seem fine with my multimeter (10A). So I hook back the battery, the power is back, start the car again, same thing.
Fuses are fine.
Never had an electrical issue before with the car.
I will bring the battery for load testing tomorrow but still I dont like that total power loss...
Or the starter is the problem.
When I disconnect the battery there is no noise at all (like if starter selenoid was stuck or something).
87NA manual.
Fuses are fine.
87NA manual.
