transmission bushings
  • transmission bushings
    Hello all
    does anyone know if the poly transmission harmonic bar bushings are available
    Not anymore
    1988 300ZX Turbo, Shiro Special #760
    1988 300ZX Turbo Automatic (wife's car)
    1991 Hard-body 2WD
    http://zccw.org/zccw/?page_id=1215
      What about the aluminum x-member
      or do I have to go oem
        Yes, you can buy poly crossmember bushings. Gary Molitor used to make the trans bushings but stop a while back.
        1991 Hard-body 2WD
          I think hardwood made some. Can maybe convince him to make a batch of bushings. I know there is interest.
          http://z31performance.com/showthread...2-2-(-now-NA2T
          My build thread (:
            I really should get on this now. haha I will try to get something going on monday. Material is what I need to look into. I've made them for my car and I can make them for you guys too.
            1985 300zx N/A - June 4 2012 Sold to Austin Irwin
            1987 2+0 N/A - March 19 2014
            1987 2+0 Turbo - May 6 2014
              This. Yes please. Let us know if you need a deposit or something to buy the material?
              My build thread (:
                I will start a thread when I find the best way to make them. Keep your eyes peeled!
                  These are the dumbbell bushings correct?
                  1991 Hard-body 2WD
                    Yes, reddzx, as seen here from harwood909's post.....
                    1986 Nissan 300ZX 300zx z31 turbo: 0.000 @ 0.000 MPH
                    http://www.youtube.com/user/thflash2007
                    http://www.facebook.com/pages/CWF-Dy...37431403027542
                      I used the early style tension rod bushings from the prothan kit, threw them on a lathe after freezing them overnight... drilling was the hard part
                        Harwood if you need anything to get this going please let me know
                        And thank you
                          Harwood any luck on figuring out thies bushings
                            Waiting for the quote from the salesmen at work, once I have that I can see if people are still interested. I chose to have them poured instead of machined so production will take a bit longer and price will be slightly higher than if I were to turn them on my own. The finished product will be much nicer and will have a similar appearance to pieces that come in Prothane kits.
                              I'm down for one maybe two sets depending on price
                              1991 Hard-body 2WD
