VG33 oil pump
  • VG33 oil pump
    I have a question for you guys that are running VG33 oil pumps. What are your oil pressure reading at idle and under heavy acceleration/boost? Also are you guys running stock VG33 oil pumps or have any of you guys had the VG33 oil pumps ported? I'm building a high output VG33 engine and want to know if I should port my VG33 oil pump or not. I want the oil pump to be able to support 30+ psi of boost @
    7-8rpm. Also what is to much oil pressure on SOHC VG engines?
    shotyme
