If you could do it again, would you stick with the 6262 or go with something else (HX35, etc.)? You seem like you've done this a few times, and I am just getting started. Thanks.
The 6262 should never be compared to an HX35. That's such an insult...
I'll post a pic of my 6262 in the stock location before my tubular manifolds later tonight.
6262 is a very good size turbo thay's capable of making over 600whp on about 25-28 psi of boost.
How much power are you looking for? Street or drag/top end performance?
See my thread about that issue here. But to save you the click, basically, I want to keep my A/C and everything I can in stock locations. Power goal is ~500hp primarily for the street. Don't need a drag monster and certainly don't want to have to flog the engine just to have fun. Wide, mid-range power band is what I like. I intend to build the bottom-end & heads, plenum/exhaust flow, and fuel/ecu work, of course.
Any advice you have is greatly appreciated. Thanks!
