Might be looking at an LSD from an '89-T, guy wants 300 bucks. Good price, or should I save for an OBX helical?
'89 lsd
I mainly want it for street driving, no track use. Is 300 a good deal? Should I have a shop rebuild it before I swap the unit?
Also, I have an '86-T 2+2, my rear end should be a 3.54, and '89-T's should have a 3.7, will it be a big difference 0-60, or highway driving (do almost none of that here)
$300 is a very good deal if it isn't beat to shit. They regularly sell for $600-$700.
1988 300ZX Turbo, Shiro Special #760
1988 300ZX Turbo Automatic (wife's car)
1991 Hard-body 2WD
http://zccw.org/zccw/?page_id=1215
If you are rebuilding you can always swap in the 3.54 Ring and Pinion but personally I would keep the 3.7.
I would rebuild with new clutch disks, bearings and seals. Might as well keep it fresh and new.86na - BlueZ
Shiro #366 - Kouki Monster
85t - Mr Tickles
I would be all over the '89 LSD for $300 !!!!!!
so, $200 shipped for clsd, but 4.6 (200zr auto) is awesome deal?
man, this set (diff and axles) located at Vladivostok (Russia), shipping will be veeeery expensive, excluding ground (sea) shipping, but I think gear set will be for sale (clsd and axles will be inserted into EUDM case with 3.54 ratio)
well, I also get for $100/shipped 200zr hood (not only scoop, assy) and 200zr auto 7blades dual speed fan (OEM set actually -1 4blades dual speed, 1-7blades dual speed into oem bracket)
