I just replaced my noisy semi-metallic pads for ATE ceramic thinking the would brake the same way they do on my Lancer GTS !
They are pretty scarry... Really need to push hard. I first tough my front calipers were stuck (after piston compressing) but no.
Do "cheap" organic pads will grab better/same as "cheap" semi-metallic ? I want no noise !
I'm only cruising on weekends but I want it to grab hard if I need to..
Also, how does 87NA brakes should compare to regular recent car ?? (ex Lancer). (everything is new except the booster...)
Thanks.
Thanks.
