OK so my brother bought a block tester from napa. (needs to replace head gasket on svx)
Anyway I used it on my Z and bad results, fluid went from blue to yellow. So that means I need to replace my head gaskets too right.
OR could something else cause a combustion leak?
Also if it is the heads you can replace the gaskets WITHOUT removing the engine right?
