lower intake manifold question
  • lower intake manifold question
    are all the vg33 lower intake manifolds the same as the vg30 I read something that said the only thing that was really different was the block and that was it the heads were the same and etc...
    Manifold
    You will need the correct lower manifold for top feed or dual feed injectors. Just use the vg30 lower intake.
