Ok i am wondering what internals would be best to use for 600hp I plan on building a vg30et to 600hp. I have heard even greater numbers reached so i figured 600 would be good fun. Anyway i would like the turbo to spool up pretty quick but still make this power so my question is could i run the 8 to one compression at a high boost to get that power without exploding. I would also like to know what fue managment system i should run. I have read alot but none concerning this much power i have read about 500hp but 100 hp more is a bit different. So here is what i would like to run 600hp and nitrous. Not sure what turbo yet i was looking at some holset turbos or gatrett. i will be useing the car for drag raceing and drifting mostly drag and some street driving(not much though). So if anyone could steer me in the correct direction i would greatly apriciate it. the only thing i am sure of is the romulator thw wide band o2 sensor,and some sort of boost control unit.
thanks
thanks
