First I must say thank you for addressing me as if I where an idiot. Second I understand the difference in Cr and could see the difference in the 7:1 and 7.3:1. i would like to see full bosst pretty early like at 3500 I think is pretty early maybe 3000 would be good to get a good power band from 3000 to 7000 rpm which would also give an awesome amount of low end torque. I would like to run the turbo at 20-25 psi (is this to high?). I was thinking about the Holset HY35/HX35 or the Garett Gt35.(sp)
thanks
thanks
