hey. I'm from Puerto Rico. I have a 88SS and want to know how much hp i'll expect from this: bar and plate intercooler, walbro 255 fuel pump, aeromotive fuel regulator and a manual boost controler. The car have a 3" cat back
How much Hp
Chris86NA2T wrote: the fuel pump and regulator will do nothing for you as you still have the stock fuel injectors and turbo. read the turbo FAQ
via the regulator. Pump would not be necessary.
Or he could use the pump and up the fuel pressure for 18psi of boost
and possibly make over 250hp with a shitty idle and bad mpg.
Use you imagination.imagination is a virtue
