^ good point.
Start here
http://www.redz31.com/turbofaq/turbo.faq.htm
How much Hp
this thread blows... direct the guy to the turbo faq and leave it at that, otherwise this will go on forever.. hes obviously just getting started and he needs to do some reading.
Domdogg123 wrote: You're not going to make 400whp with the stock turbo unless you're using nitrous.
Well... let's see what happen. i'mworking with the intercooler and plan to run 12-14 psi with 93 octane. I also have iin mind buy a microtech that my neighbor has. But i want ~400 RWHP. Can i make it?
Chris86NA2T wrote: the fuel pump and regulator will do nothing for you as you still have the stock fuel injectors and turbo. read the turbo FAQ
via the regulator. Pump would not be necessary.
Or he could use the pump and up the fuel pressure for 18psi of boost
and possibly make over 250hp with a shitty idle and bad mpg.
Use you imagination.
high_speed wrote: Some suggestions or options where i can buy a good injectors! thanx
New and used Precision, RC Engineering and Siemens Injectors in all sizes are always on there for cheap
my neighbor is selling a microtech for $750. it comes with a hand tool and is perfect for the Z. I have to change the injectors. Some suggestions or options where i can buy a good injectors! thanx
How much Hp
hey. I'm from Puerto Rico. I have a 88SS and want to know how much hp i'll expect from this: bar and plate intercooler, walbro 255 fuel pump, aeromotive fuel regulator and a manual boost controler. The car have a 3" cat backTags: None
