the needle on my boost guage is only going a hair past 0 and i have noticed a drop in power so im guessing the guage is working any ideas what it could be its an 85 and completly stock with 116000 miles
turbo?
boost leak. have you checked for leaks. have you checked the vacuum lines on the compressor housing to see if they have fallen off?
maybe this should be in the newbie forum.Another one dead: 1985 2+2 GLL, stripped going to the recycler!!! doing my part to stop global warming!
the sierra club is gay!!!
84z31 wrote: boost leak. have you checked for leaks. have you checked the vacuum lines on the compressor housing to see if they have fallen off?
maybe this should be in the newbie forum.85 Z31 6.0 LSX turbo 766whp/792wtq
look under the hood on the drivers side fender.. try to find a little black box with a wire plug and a vacuum line going to it. somewhere on the black box it will say "boost sensor" that vacuum line is cracked at the nipple on the boost sensor.. take it off and cut off the cracked end. plug it back in and drive the car to confirm that this is your problem.. if that fixes it then go out and buy all new vacuum lines for the whole engine, replace them one by one.. this is the problem 99% of the time. i have seen it on many many z31's.. oh, if you dont see the crack in the line in the exact space i described then check the entire vacuum line going to the boost sensor
you're right, i was not thinking clearly.ops: to much mountian dew and calc.
[quote]SATAN wrote:Originally posted by 84z31boost leak. have you checked for leaks. have you checked the vacuum lines on the compressor housing to see if they have fallen off?
Uh, if the hoses fell off of the comp housing, he would be boosting all over the place!Another one dead: 1985 2+2 GLL, stripped going to the recycler!!! doing my part to stop global warming!
