Good start huh? As a way of introduction my name is Mike. I'm in Houston. I've been driving z's for bout 10 years or so. Had 2 s130's, one T and one NA. Bought an '85 z31T in late 2000. Posted on other boards as zenarcher, mike85t, freewill. I had the linkmaker pages, the original vac lines page, and a couple other pages that were used a bit. So some of you know me to some degree or another. I sold the '85t a while back. Now I have an '88ss. I was just looking for an 88t but this deal was way too good to pass up. The price was so good I could put a new engine in and still have a good deal. I bought it with a blown HG. I'm getting the parts together for repairs and stuff. The engine is modded quite a bit. Has a tec3 w/ coil packs and MAP, cam, and crank position sensors, JUN pistons & rings, JWT S2 cams (dunno about the springs) Spearco ic, Aero FPR, and a few other small things that I can't recall right now. Oh and according to the PO it has 850cc injectors which seems like massive overkill to me. The turbo looks like a Nissan t3 but the PO says he had both sides machined and bigger wheels installed. I'm thinking better turbo after tax refund and profit sharing bonus.
The car itself is beautiful. Check it out here No body work and no rust except a little in the hatch area and under the battery tray all of which I've already taken care of.
Anyway, the engine ecu mods are way over my head so I have a lot of learning to do. And a few questions to begin with for the HG and t-belt replacement.
I can do the work w/o setting TDC but for reference sake I'd rather set it in case something gets screwed up. Is there a simple way to find TDC w/o having a distributor?
And if I can't set TDC am I right in thinking I should mark the external crank sensor parts and the "wheel with 2 teeth missing" that's mounted in front of the harmonic dampener?
And next I'd like to replace some of the crappy wiring. Some of the aftermarket wiring starts with one color/gauge and goes through one or two color/gauge changes before reaching it's destination. The injector clips are mostly trashed. Top feed injectors if that makes a difference. And the injector wiring is old and badly spliced. What's a good gauge wire for that?
In the meantime I'll be cleaning up the engine bay. No disrespect to the PO but it's not reassuring that someone could spend so much money on a car and not keep it clean. Looks like 18 years od hydrocarbon leftovers. I'm cleaning everyhting behind the bolts and brackets on the inner wells and the firewall and front braces. Next thing to go will be the breather cap on the drivers side valve cover. Maybe install a catch can?
If you read all this...thanks. If you read all this and didn't post about people getting in over their heads then double thanks
