What size aftermarket cone filters are you guys using? Im thinking about going K&N or TG... Is there a limit to how big you should go? The more air the better, right?
Cone Filter Size
I wouldnt worry about going too big. There is a point where it wont do you any more good to be bigger but as long as it is filtering the particles small enough then you are fine. Now too small on the other hand, thats different.85 Z31 6.0 LSX turbo 766whp/792wtq
