So I picked up a z32 N/A motor and plan on going with an all motor build. So before I start spending money and things that don't need to be done, what do you guys suggest I mod? So far I'm thinking: High Compression pistons, Boring 20 or 40 over, slightly larger injectors, lightweight flywheel mated to a stage 3 clutch, Lightened and balanced crankshaft, and shaving the heads. What else should be added to this list that I haven't thought of? Mind you, this is my first motor build and I will not be doing it alone, so if I dont understand something you mentioned just bear with me.
Thanks
Thanks
