sensor light came on
  • sensor light came on
    hey guys about 2 weeks ago my sensor light came on and i was searching on ways to reset it this is what i found on z31.com
    Remove the glovebox as follows:
    Drop the glovebox door by pressing in the sides releasing the door stops from their holes.
    Remove the screws (4 trim/2 latch).
    Pull the box out and lower it out of the way.
    At the top of the glovebox frame slightly to the left locate a relay. On the right side of the relay you'll feel a rubber-covered button/plunger. Press it in and you'll hear the relay spring reset. Turn the ignition switch on, the sensor light should be off.
    Reassemble.
    Enjoy the ride!
    i did all of this, and i could not find what he is talking about, any1 have any pics of this relay or the button
    thanks
    I hate wheel gap with a extreme passion
    my build
    viewtopic.php?t=2755
    seller feedback
    viewtopic.php?f=18&t=10430
    Or if the car has over 90,000 (I think that's the #) you can simply disconnect it altogether.
    Unless you want to keep the functionality.
    There is a procedure in the FSM and I *think* the Haynes that shows you where the connector is you unplug.
    I don't have either one sitting in front of me right now unfortunately.
    I can look when I get home though.
    PT
    - Visit my Z31 Cardomain pages -|- Visit my website! / 73, de AE5NW -
    The phrase "It's just the Internet" is not an excuse to be an illiterate dolt.
      I thought that plug for the exhaust gas senseor was under the steering wheel?
        it is, more towards the drivers side door.
        MrwassmanNA2T wrote: I thought that plug for the exhaust gas senseor was under the steering wheel?
        the sierra club is gay!!!
