hey guys about 2 weeks ago my sensor light came on and i was searching on ways to reset it this is what i found on z31.com
Remove the glovebox as follows:
Drop the glovebox door by pressing in the sides releasing the door stops from their holes.
Remove the screws (4 trim/2 latch).
Pull the box out and lower it out of the way.
At the top of the glovebox frame slightly to the left locate a relay. On the right side of the relay you'll feel a rubber-covered button/plunger. Press it in and you'll hear the relay spring reset. Turn the ignition switch on, the sensor light should be off.
Reassemble.
Enjoy the ride!
i did all of this, and i could not find what he is talking about, any1 have any pics of this relay or the button
thanks
Reassemble.
Enjoy the ride!
thanks
