Team Green filter, how to clean.
  • Team Green filter, how to clean.
    So i got this cone filter from OR-Zman sometime last year and put it in.
    I had thought that they were "dry filters" and didn't require the solvent
    cleaning/re oiling that the K&N filters did.
    It is quite dirty now.
    I have the cleaning/oiling kit from my K&N filter.
    Is it safe to use the K&N kit ?
    I see that Team Green offers a cleaning/oiling kit on their site, which
    leads me to believe that my assumption that the filter is "dry" is incorrect.
    I'm sure the "super clean" type degreaser/cleaner in the two kits would
    be similar, but not sure about the oil.
    Thanks.
    i wouldnt use the oil. too much of it can mess up your maf.
    Bolt on, fast, z31. You can only pick two.
    Old weaksauce numbers: 391hp/433tq
      Oil for foam and oil for paper is different. Motorcycle filter oil would probably work pretty well.
        Sorry about that. I though you knew they were oiled filters. They come from the factory oiled but I probably didn't have the Info piece of paper in the box when I sent it to you. oops...
        I havent needed to clean my TG panel filter yet but I would stick with the TG oil/cleaner. I just went out to check but I couldn't find my old bottle of K&N oil, but the TG oil is pretty thin. Much thinner than I remember the K&N oil being and its a spray on oil that comes out in a pretty fine mist. I wouldn't use the K&N if I were you.
        I got the cleaning kit from TSS, I'm not aware of any dealers here in OR.
        I wish I was closer and I would just bring my stuff over and you could use it.
          OR-Zman wrote: Sorry about that. I though you knew they were oiled filters. They come from the factory oiled but I probably didn't have the Info piece of paper in the box when I sent it to you. oops...
          No Problemo. Thanks for the offer.
          I had thought i read somewhere that they were a dry filter and would not have thought twice
          about it until i noticed that they had a cleaning and re-oiling kit on their site.
          There is an RC/Hobby or kart shop in portland that is on their distributor list, i'll check there.
          Thanks for the info.
            IIRC TG recommends NOT to use the K&N filter oil as it will discolor your filter. RED + GREEN = :x . Get the right jizz for your shiz.....
              I used some pj1 cleaner and filter oil for a dirtbike aif filter and had no problems. The oil is a fine aerosol mist.
              Shiro Special # 981 Being assembled in my spare time Chromoly acquired!
              Originally posted by BoostedMamma
              Heads up makes teh panties drop. BUT I don't have a penis OR a fast car, so I guess my opinion doesn't count.
                z
                  apexi and blitz are dry, blitz is the ss mesh, while apexi looks just like k&n
