i think mine died.
i reved the engine to 6000 rpm doing a burn out. :roll:
right after that the car will not idle. i checked for vacuum leaks. i didn't have any.
other history. no emissions crap. 88NA computer in an 85 with resistors.
checked the timing. its perfect. the timing belt is lined up perfect. the distributor is working and lined up. the fuel pump works. the injectors are firing. no vac leaks.
i'm going to check the computer for codes in a minute.
is there a way to test the MAF?? i can't seem to find anything in the FSM about testing it.
thanks
thanks
