Knock out a few questions with one thread:
If you haven't followed my project, the heads are off.
1. It's okay to assume that I'm an idjit
This car is way more advanced than anything I ever intended to own but it's what I got and regardless of my tech abilities I'm into it.
2. I'm cleaning the tops of the pistons and the two that were at the top of their bores are clean. It would be a pain to clean the others w/o bringing them to the top of their bores. It isn't going to hurt anything to turn the crank and bring them up is it? Can't imagine why it would. Obviously I'll return the original position when I beging to put everything back together.
3. I'm removing the valves. Assuming everything else is okay do I need to replace anything other than the seals? If I got +1mm Ferrea valves would I need new guides and whatnot? I prolly don't need them and I'd just as soon have the stock size but I have a line on some +1mm for a lot less than the stock size.
4. Should I remove the cams to clean the heads up? If I do, what should I watch out for?
I don't have my FSM handy but I'm assuming it has all the info I need to reinstall everything, like assembly lube type etc?
5. Does the engine oil cycle in and out of the lifters? What I'm getting at is whether the oil/water crap from the blown HG is likely to be in them. If so I'll clean & rebuild them.
BTW, I paypaled some $ to help support this site and I recommend everyone who isn't a "guru" and doesn't need to ask questions like this do the same. The support and knowledge base here is worth every penny.
