IC Coupler/Clamp Inquiry
  • IC Coupler/Clamp Inquiry
    Hay guys...
    I think I found a boost leak in my IC setup. A little backgorund, I got the hks fmic setup. When the car is cold, it holds boost fine. Once warm, the car still boosts, but not as much & the turbo spool sounds strange. A "hissing" noise, so Im thinking I got a boost leak on my hands.
    Im gonna investigate other things & re-tighten clamps but while I have it off, might as well get some clamps more conducive to higher boost levels. Since Im assuming the HKS was designed for stock use.
    Theres two points where I think it is failing. Right when it exits the turbo, the turbo has a big "lip" on it. I have the clamp tight on the "lip" but I swear when it gets warm, it leaks. Plus that lip causes the IC coupler to line up funny (cuz I think the thinckness of the lip causes it to be bigger than 2").
    Also under the car, at the point where my IC pipe curves into the actual tank itself, its misaligned (due to non-stock fitment), so that piece is suspect too.
    Everywhere else on the car, the pipes are aligned and fit nicely. Theres guys running 20+psi through this same hks setup, so the pipes can flow it (dont know bout stock turbo tho). Those two areas either need better couplers and/or stronger "boost-proof" clamps (right now im using standard clamps). What do ya'll use/recommend???
    Turbo lip looks like this:
    http://performance-online.co.za/shop...62e00094260c1f
    ***Cardomain Site***
    I use high quality T-bolt clamps, the leaks should be very easy to find if it's that bad...
    http://youtube.com/c/zcartube
      yeah, I think I isolated where its leaking. Its hard with car just sitting there to be sure, might try to pressure test it (if I can find someone with one ghetto-rigged up already)
      T-clamps sound good. The pipes are bead-rolled, so I think normal clamps are fine for inter-pipe connections. But will get t-clamps for both IC tanks connections, the throttle body connections, and that turbo lip connection. Maybe some silicone couplers too.
      Know any good websites with good prices? or is eBay any good for these?
        joeyfeets wrote: yeah, I think I isolated where its leaking. Its hard with car just sitting there to be sure, might try to pressure test it (if I can find someone with one ghetto-rigged up already)
        Ebay is good however, if you are gonna do T-bolts then dont cheap out. Find out all the sizes you need and tbolt the whole thing. Lots of sites on ebay will allow you to mix and match sizes. Just do some searching.
          Clamps
          I know around here that alot of plumbing shop carry T-bolt clamps...and also if there is a shop around you that deals with hydraulics, or pneumatics try there...I found some for 1.30-2.50 a clamp when everybody else was asking 4-10.00 per clamp!!!
          88na2T-s13,q45 swap 12.6@110mph
          87T 2+2 auto,stock
            theres nobody that sells t-bolts at stores?
              Re: Clamps
              DMANN wrote: I know around here that alot of plumbing shop carry T-bolt clamps...and also if there is a shop around you that deals with hydraulics, or pneumatics try there...I found some for 1.30-2.50 a clamp when everybody else was asking 4-10.00 per clamp!!!
              You pay for what you get... Whats worse, paying a few extra dollars for some good high quality clamps or having a pipe blow off doing 100mph at 12psi+? :P
                Re: Clamps
                Yeah but a T-bolt clamp is a little different then say I dunno, A TURBO. T-bolt clamps are cheap to produce and should NOT cost 10 bucks a clamp. which I have also seen. That is just rediculous. I would say 2.50 a clamp is a fair deal.
                  Definately, $10 is certainly up there lol I got a box of 10 for like $40AU if I remember correctly...
                    Clamps
                    Well....maybe in the US but not around here!!!!
                    Princess Auto 5-10 per clamp...cheapest around here...till I found the same stainless T-bolt clamps at Windsor Factory Supply for 2-4 a peice.
                    and yes they do sell them in stores...you just have to know what stores to look in around here...
                    87T 2+2 auto,stock
                      If you find a Dodge cummins diesal(or maybe other turbo diesal trucks) at a junk yard, nab there clamps.
                        this site has some: http://hosetechniques.com/
                        $6.50 per clamp!!! at that price, im only replacing the non-beaded stuff first. I might try some plumbing supply stores...
                          http://www.siliconeintakes.com/
                          Where I ordered my reducers and some clamps from. Good prices!
                            napa carries them, they are called heavy-duty or something, check the parts catalog with the sales clerk
                              you can try here for them, we use them all the time..
                              http://www.partssystems.com/shop/produc ... y_id=TBOLT
                              Gone - 1988 Shiro
                              2004 BMW 330Ci
                              2005 BMW 330i
                              1991 Twin Turbo Z's (Red and Black)
                              http://www.E46Turbo330Ci.com
