i just bought a 85 300zx turbo. it had a blown motor. i rebuilt the motor, ballanced, bored .050mm, 3 angle valve job , port matched the intake, mild ported and polished the exhaust, ported and polished the cast manifolds the best i could. rebuilt the turbo . and ported the perssure outlet. the car also has a k&n cold air intake, no cat, flowmaster muffler, centerforce clutch. it runs good, spools quick, and shows 6 to 6 1/2 lbs. boost. whats next ? i would like to up the boost more . but where to start. the rebuild took most my play money for now , but... can you just remove the POV with out adding a BOV? how about a manual boost controler? i have seen some stuff on here about moding the fuel pump curcuit, what do you do? where does the factory fuel cut come in at? i have had it pulling to 6500 rpm allready.
i hot rod everything i own , just have not played with a newer turbo nissan before , so i like to ask lots of questions.
