255lph Walbro pump, need AFPR?
  • 255lph Walbro pump, need AFPR?
    Subject title says it all, do I need an adjustable fuel pressure regulator when upgrading to the 255lph walbro fuel pump to regulate the fuel pressure or will the stock regulator keep it at the correct base pressure?
    88T => 300zxt
    http://www.300zxt.com
    88T wrote: Subject title says it all, do I need an adjustable fuel pressure regulator when upgrading to the 255lph walbro fuel pump to regulate the fuel pressure or will the stock regulator keep it at the correct base pressure?
    stock should work. but afpr are nice any ways.
    BLOZ UP.com
      Well I need to know if it will still run the correct base pressure even with a high pressure fuel pump...
      88T => 300zxt
        It'll run the same pressure no problem. You dont need an afpr.
          Of course you don't need one. Who's feeding you that garbage?
            I dunno where I heard that, oh well that's cool! One less thing I need immediately
            88T => 300zxt
              Jason84NA2T wrote: Who's feeding you that garbage?
              hahaha
              it helps to understand how the fpr actually works, I would bet most people do not.... it's not something that exists in a carb application so some people will have a mental block accepting that it's just a return line restrictor
              simply it lets most fuel flow through it at idle and the least at wot.... the rail is pressurized by the pump, the fpr bleeds off excess fuel to reduce the pressure to the required amount, which is ~37psi for us
              the only time you'd need to upgrade is if you were overwhelming it at idle, which is close to impossible unless you have upgraded the fuel supply hose and hardlines to say 3/8" and run a monster pump or two, but even then it would only affect low rpm/throttle only
              and the only other reason to upgrade would be to an adjustable unit that could raise or lower pressure as needed in the tuning process
                Excellent, thanks for clearing that up...
                88T => 300zxt
