I jus bought a totally stock 85 turbo with 100k everthing works great ecepte a minor oil leak i wanna do some mods to make it quicker when what are some good ones to start with
What Mods
Hi there
As the other guys have said before you even do anything do the oil seal and depending on where it is this may be a good chance to replace a few other gaskets/oil seals while your in there.
whenever i buy a car i do a fairly simple but effectrive service on it
cambelt and idle/tension bearings
waterpump
new coolant / radiator flush
fuel pump- dammit i mean fuel filter
from here its up to you how you go about doing things READ READ READ jasons imformation.85 Turbo Slick Top
