How can I raise the boost a lil without buying a controller.. or something.
How to raise the boost
well you can detach the wastegate hose and plug both ends if you want to blow up your engine... or you can crimp the wastegate hose if you want unsafe and unknown results... or you can *gulp* spend $15 on an MBC on ebay and stop being a cheapass.
Have a nice day.1985 NA2T(now RB) * 1988 SS x2 * 1984 AE x3 * 2006 350Z
Here's your answer: Don't
~first get a guage, cheap ones are $30 on ebay.
~ball-spring controllers are $20 on ebay and take two hours at most to install on a stock car.
so for $50 you can have a gain of ~20-25hp on good gas, cut your muffler off and add a straight exhaust pipe for a gain of another ~20hp for $8.
