I'm interested in replacing my mounts and bushings, I want to upgrade to poly/ solid so I wont have to worry about them ever again.
I have come across Stubby solid motor mounts on ASCO, vibrations aside being able to lower the engine to be able to install a Pathfinder plenum sounds good to me.
My concern is how things will line up, for the transmission ASCO has Polyurethane mounts, will they do fine with the engine being lower on solid mounts, will I need something specific?
Thank you
Thank you
