Ok, I'm a newbie here, but I see many pics of Vg's without the timing belt cover on. Can anyone comment from personal experience if they've done this and would recommend against it for wear reasons?
OK to remove timing belt cover - permanently?
Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
spy a VG30et.. a VG30ET 510?
Tube frame "done".
12/10: Interior sheetmetal, firewall done. Fuel + brake plumbing "done". Pulled it all out again to finish the "chassis". Briefly, it drove, then back to the shop.
1/11: rotisserie built: car BELLY UP
Will now attempt an aero underbody - best keep it simple!! I have no windtunnelTags: None
I have not run the front upper cover for some time and have never had an issue... even driving on dirt. I have never driven on a timing belt over 40K miles though. I'll admit I've always been just a little bit concerned about it.
The lower covers and rear part of the cover I would absolutely keep in place.
I found a good trick to making the upper cover easy to remove is cutting it down the middle..... the section between the cam gears has two tabs for bolts, you can cut vertically between them so each side keeps one and the cover will not be loose
then when you want to remove it, you can easily twist it out from under the belts and hoses and stuff.... assuming you don't have a/c you can get both off quickly
I'm leaving mine off just to expose the sexy blue camgears hehe The main danger I think is not to get stuff caught in it if doing anything in the enginebay while it's running like hair or a sweater or something otherwise you could find your face being buzzed off by the camgears lol
I dont run either of mine, top or bottom. BUt the less you have protecting your timing belt the better chance you have of destroying your engine.
up to you.85 Z31 6.0 LSX turbo 766whp/792wtq
How did you go about removing that rear cover Alex? Mines all bent and sh!t and doesnt look too pretty, I wouldnt mind removing it either if there are no ill effects in doing so...
eh, yes. The newbie forum is where this belongs.
Thanks for the info, guys! - very helpful. Seems like the big H.P. guys like to run the belts semi-naked! I think I'll do it too, slave to fashion that I am...Started with Datsuns and L engines, Mikuni carbs. Now a 1968 Datsun 510: 2200lbs, RWD, IRS, 50:50wt. f/r
Tube frame "done".
Yeah that's what I thought, good timing too because I'm installing Russ's cam gears very soon. He was nice enough to swap out my red set for a blue set just because
