cam gears question
  • cam gears question
    Looking at the engine from the front of the car, the gear labeled R3 should be on the right hand side, correct?
    Just wondering cause i have one car that has them backwards and i don't know which one.
    KILL HADJI
    No, it's as you sit in the car. If you're looking at it from the front (backwards), R will be the left and L will be the right.
      Stage left/right! lol
      http://youtube.com/c/zcartube
        Jason84NA2T wrote: No, it's as you sit in the car. If you're looking at it from the front (backwards), R will be the left and L will be the right.
        :lol:
        YUP!...a very common mistake made by even good mechanics unfamiliar with the VG. The car will still run, just no where's like it used to or should.
        I am here to help...
