what are the effects of putting a twin turbo fuel filter on the Z31?
Z32 Twin Turbo fuel filter
The difference is pretty neglidgable. Unless you are putting out major power and are trying to squeeze the last drop out of your fuel pump or something. It's probably not worth your effort, especially since the Z32TT filter won't really fit in the Z31 mounting bracket without some changes.My beloved Z:1987 2+2 NA2T w/30a swap.
Morgenstern wrote: well it allow me to go from 9.5 psi to 11 psi maybe? or just 10 psi?" I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
btw this should be in the newbie section ( you should really start searching for this crap on z31.com)
what i meant by that question, is if having the TT fuel filter will allow for me to up the boost from 9.5 psi to 10-11 psi SAFELY. i know that having the TT fuel filter won't naturally allow for 1-2 psi gains, i'm not that fucking dumb. and now i'm not a fucking newbie i'm just asking if the filter will give the motor a little more fuel to allow for me to boost 1-2 psi more over 9.5 psi?
you dont need a fuel filter to hit an extra pound of boost or two , the fpr will control the fuel pressure(this wont change because of a higher flowing fuel filter) and the fuel pump flows enough for 300hp(which you will never make at 10-12 psi on a stock turbo)
If I had to replace my filter anyways I would go ahead and throw a TT filter in there. :?:Attached Files85 Z31 6.0 LSX turbo 766whp/792wtq
I dont really see the point to be honest, especially considering that the JDM VQ35DE fuel filter is the exact same part number as the Z31 fuel filter so it must work pretty good if Nissan still recommend it for their newer engines.
300zxt wrote: I dont really see the point to be honest, especially considering that the JDM VQ35DE fuel filter is the exact same part number as the Z31 fuel filter so it must work pretty good if Nissan still recommend it for their newer engines.
It's all a theory until someone actually tests it.
"The point" relates to fuel flow restriction and pressure drop in the system. By usling a filter that is easier to push fuel through you make the pump's job a little tiny bit easier when it has to flow high volume at high pressure. This is only if you're talking about moving a lot of fuel.. most engines (my own included) will never need fuel flow in the neighborhood of 200+LPH (550cc injectors at 100% duty).
