lean?
  • lean?
    hey just to get this out of the way... i dont really know much about cars but im tryin to learn and im ready to break mine tryin to fix it. alright well i got a 1986 n/a and ever since i got it its been kinda slow. its got 176000 miles on it but runs fine for the most part, ahnd the engine still pulls pretty good but... the last half of the gas pedel doesnt seem to do much ... im guessin its something with fuel gettin to the engine ( dont know if its injectors or fuel pump or what) it also doesnt pick up as you go up in rpms like it should ( actually looses power aruond 4k) and it wont start if its reaaaly hot out and i drive it for a bit. I also just replaced the plugs and wires and the plugs where all WHITE...
    thanks a ton
    btw i ran some pennzoil fuel system stuff thru it a while ago and it didnt seem to make a difference
    THE MAFIA STRIKES AGAIN!!!
    i also was just readin about that seafoam gunk and figured it wouldnt hurt so how would i go about puttin that in
      If you think it is fuel related, check the pressure and if you want to clean your injectors do it the right way: have them flow tested and properly cleaned.
      Chuck Stong
      http://www.300-plus.com
        how much does that run? or is there i way i could do it myself?
          Double check the timing belt installation. If the cam gears are backwards or it is a tooth off on a cam it would exhibit behavior very similar to what you describe.
            ooooh uh yeha they said the timing belt only had like 37 of the 60 or so thousand miles on the timing belt... but its from 98 so its kinda old and should i be worrying about that?
              yes, interference engine and broken timing belt = bad
                mormonmopedmafia wrote: ooooh uh yeha they said the timing belt only had like 37 of the 60 or so thousand miles on the timing belt... but its from 98 so its kinda old and should i be worrying about that?
                Check it for any cracks when you check the cam timing. You should most likely replace it either way, along with the water pump.
                Timing belts are hard to proove they were done, and then you still can't show they were done correctly. Never trust the previous owner.
                  Jason84NA2T wrote: Never trust the previous owner.
                  Thats the truth!
                  Drive
                  1975 Datsun 280Z
                  1988 300ZX (NAtoT soon)
                  2006 Kawasaki ZX6R
                    well looks like i need to start savin some money cause my dad wont let me tear into my car that much
                    do you think its agood idea to do the seafoam anyways just to clean stuff out? i had a stickin lifter a while ago but it quit when i changed the oil so i dunno
                      Sure.
                      imagination is a virtue
                        mormonmopedmafia wrote: how much does that run? or is there i way i could do it myself?
                        About $20 to 25 per injector. This can really bring back a car if the injectors are not flowing well.
                        Chuck Stong
                          damn.... do you think that would help my issue or does it sound like somehting else... ( timing belt)
                          • #14
                            mormonmopedmafia wrote: damn.... do you think that would help my issue or does it sound like somehting else... ( timing belt)
                            It is just too hard to diagnose without seeing the car. My advice is to thoughly check the car before spending money on parts you might not need.
                            Chuck Stong
                            • #15
                              alright how would i go about "thuroughly checking " it?
