calling all NA 2 T guys!
  • calling all NA 2 T guys!
    ok well turbo conversion is all done except for the fact that the engine will not start!
    here is where i am at!
    87 NT with an 84T engine and 84T ecu!
    i have fuel pressure
    i have spark
    im 100% sure that the timing belt is correct
    even tried moving the ditributor both ways, i tooth ata time
    im wondering is there any difference between the NA and T engine harness! Also from the 87 harness to the84 engine was there any change in the fuell injectors wires?
    there is also some back firing while is cranking over!
    any input would be greatly appreciated!!
    http://www.youtube.com/user/onefast87
    Are the injectors firing? Maybe try moving dist 180 degrees. Double check electrical connections and fusable links.
    Chuck Stong
    http://www.300-plus.com
      i moved the distributor 180deg both ways
      how do you cehck if the injectors are firing? wouldnt the car have to run first?
        onefast87 wrote: i moved the distributor 180deg both ways
        with the ignition ON, you can turn the distributer back and forth and hear the injectors fire.
        2000 Porsche Boxster
        2007 Toyota Yaris
          The only differences that you should run into as far as wiring goes is the alternator harness being on the drivers side on an 84-86 NA, where everything else has it on the passenger side. Also, on the AAC/FICD connector, the NA has it as one large 4 prong connector, the turbo has it as two dual prong connectors.
          If you want to figure out if you're getting fuel into the cylinders or not, try spraying some fo that quick start stuff ( forgot exact name ) into the intake and see if it tries to start with that. If it does, you probably have a fuel problem..
            If you have spark then you can assume the ECU and related electronics are working. In my experience, the injector connector terminals on the wiring harness will get corroded and not make good contact.
            To check for fuel signal/supply:
            -Use a multimeter with pulsewidth monitoring ability.
            -Put a large screwdriver down onto the injector body and your ear on the other end. Have someone else turn the engine over while you listen to each injector. You will hear a distinct click every time the injector fires.
            -Pull a spark plug and see if it's wet with fuel after cranking.
            -Last resort: starting fluid
            If you're not done checking for incorrect timing try putting the engine at TDC and try setting the dist according to the picture in the haynes manual, if it does not start flip it 180 degrees...
              If you re wired your idle air control like you were supposed to, check your wiring again. Mine was grounding out causing the fuel pump not to get enough power.
              545 RWHP & 540 RWTQ
                ok guys
                took the distributor out for the 6th time
                set it TDC, placed the distributor back in, and voila it started
                it runs rough, i seem have a few leaks on the intake
                but it ran under its own power
                i must have made an error somewhere along the line
                this is like the 5th motor i have put into a zed, and this was the first time it happened
                just want to say thanks to those that helped
                pics are comming soon
                  onefast87 wrote: ok guys
                  Cool. Glad to hear you have it running.
                  545 RWHP & 540 RWTQ
