Drivetrain swap
  • Drivetrain swap
    im looking to drop my whole drivetrain from my 88t to a 87 88 89 N/A 300zx.... how hard is this really going to be all i need to swap is the engine cross member right?...or even if i wanted to switch automatic to 5 spd...how hard is that?...it seems easy ....plus i have all my parts from my 88t
    TurboZkid wrote: im looking to drop my whole drivetrain from my 88t to a 87 88 89 N/A 300zx.... how hard is this really going to be all i need to swap is the engine cross member right?...or even if i wanted to switch automatic to 5 spd...how hard is that?...it seems easy ....plus i have all my parts from my 88t
    First of all, WHY?
    Second of all, are you swapping transmission back or engine as well? Transmission back, everything is a bolt on change. You'll need all the hardware/accessories that go with whatever you're changing.
    545 RWHP & 540 RWTQ
      If you have both cars, you should have no problems. Yes, you do need to swap the crossmember. Don't forget the radiator, as the turbo is a dual core, na is single.
        Firehawk wrote: If you have both cars, you should have no problems. Yes, you do need to swap the crossmember. Don't forget the radiator, as the turbo is a dual core, na is single.
        Chuck is 100% correct, however it should be noted that I and several other NA2T guys have ran the NA radiator with no problems. I'm still a shortwhile from having my intercooler installed, so it will be interesting to see the cooling difference. However, It would be advisable to eventually swap to the dual core.
        545 RWHP & 540 RWTQ
          if you have the dual core do it... My single def. lacks.
