i'm taking a wild guess in what that's called, but i'm sure it's some sort of sensor to the distributor. well the wires from the ECU i think have a short, and it's 'causing my car to misfire.
but fortunatly enough i'm in the process of fixing it...only problem is i don't know where to start. will just cutting the wires and connecting them with butts work, or will i have to find this possible "short" and eliminate it? since this is most likely coming from the wiring harness i'm a little bummed and hoping it's nothing serious. any ideas would be great, thanks.
