So this December I'm planning on some gauges to go with my na2t thing. I'm thinking of just getting the pillar from Dan at TSS and get a boost gauge for it. My question is what other gauge should i get? I'm thinking an oil temperature gauge would be good. I don't race, or even drive very hard, but we have many long straight roads here in NE and one could conceivably stay on boost for long periods of time. I could go with anything, coolant temp, oil pressure, you name it. What are your opinions? Also, where do i get the maroon paint to spray the pod with? Is it worth the trouble to paint? I suppose I'm going to end up taking the dash off at some point to do this... :?
Another option: I've seen people put aftermarket gauges in the factory gauge holes in the dash. I really like that, but I don't know how to do it. Not being very creative I'm probably going to go with the easier-to-do pillar mount.
Also, Dan, if you read this, do you have a 20psi gauge availible? Only the 30psi is listed online...I don't need that too bad.
Any thoughts/opinions welcomed...
