just thought i would share my setup here.. i ripped out the climate control and replaced it with this aluminum plate. on the left, the knob is for fan speed. it used a blower motor resistor from a 240z giving me 3 fan speeds. the 4 buttons control the vacuum solenoids for the front vents, floor vents and the recirc vent doors. the 4th button is for the heater core door. the profec b is mounted in the middle as you can see, and the 2 usb ports are for the romulator and LM1. the romulator is burried behind the dash on the firewall above the passengers feet and the LM1 is in the glove box. the usb to serial adapters are burried behind the dash. everything works great and im very happy to have gotten rid of the barely functioning 20 year old stock stuff. plus it has made much more room for cool things. everyone that has seen the setup really likes it so i figured i would post it.
climate control/boost controller/usb port...
i like , i recently did somethin similar , but i used platic and i just j-b welded it to the trim plate thing , i did this because i was in a rush to get a home for my AEM w/b gauge (52? mm gauge= tight fit) . i plan to put a fuel press gauge and maybe an EGT gauge or something else , and one simple switch for the blower , im going to rig the vents closed so it all blows towards the windshield .
one question , do you have any pics of how you supported the face plate?
Thats pretty cool! I have an aluminum plate there as well only mine is black. I dont need the heater controls due to the lack of heater but I was trying to think of what else to put there cause its blank now except for my battery swithch. I like the usb ports. I may have to do that for my LM1
2+2turbo wrote: i like , i recently did somethin similar , but i used platic and i just j-b welded it to the trim plate thing , i did this because i was in a rush to get a home for my AEM w/b gauge (52? mm gauge= tight fit) . i plan to put a fuel press gauge and maybe an EGT gauge or something else , and one simple switch for the blower , im going to rig the vents closed so it all blows towards the windshield .
one question , do you have any pics of how you supported the face plate?85 Z31 6.0 LSX turbo 766whp/792wtq
Yeah on mine you can see the brass rivets on the sides (they hold in L angle) so I can slide my plates in and out in case I have to make a different one, like I will probably have to do now that I dont have that wide band gauge anymore.85 Z31 6.0 LSX turbo 766whp/792wtq
[quote]SATAN wrote:Originally posted by 2+2turboi like , i recently did somethin similar , but i used platic and i just j-b welded it to the trim plate thing , i did this because i was in a rush to get a home for my AEM w/b gauge (52? mm gauge= tight fit) . i plan to put a fuel press gauge and maybe an EGT gauge or something else , and one simple switch for the blower , im going to rig the vents closed so it all blows towards the windshield .
Hey 2+2turbo there is your AEM wide band right there in my pic LOL
52mm gauges in slot where a/c control unit used to be = tight fit.
i plan on sticking two more gauges next to it.
in need to clean my car! ops:
HAHAHAHAHA!!!!!! They screwed up and put all of your shit on the right side of the car! fricken retards!
All the orange looks cool. reminds me of the 944 porsches.85 Z31 6.0 LSX turbo 766whp/792wtq
