twin intakes in the hood of the 88
eagle rods
38 mm external wastegate
mild port/polish
3 angle valve job
custom intercooler piping
rad moved back
romulator
420cc injectors
walbro 255lph in-line fuel pump.... and lots of headaches... lolTags: None
As for the ugly.. well i guess that's a matter of opinion, most seem to like it so far that have seen it. Why dual afms? well because if they both register half the air and they are hooked up in parralell they will send an average voltage that the computer should read as half the airflow that it expects, then mutiply the k value by 2 and it should be able to flow 600 hp i think. maybe i'm wrong but it works in my head so far. It was a cheap alternative to a single z32 maf and that's really about it. The z32 guys do it occasionally so i figured why not on the z31? And as for what ecu -- the stock ecu and a romulator which has been causing me major issues that hopefully i can resolve soon. (btw -- i've been running on one intake and one maf for initial tuning)8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
hmm i dont know it just looks so ricearoni to me , how wil the hood be able to open anyway? , is this drag only car or something?? what about the rain,snow?? and if the 2-afm thing works out for you maybe il try that out when i max my single z31 afm.... i have another afm sittting around..
t70 wrote: As for the ugly.. well i guess that's a matter of opinion, most seem to like it so far that have seen it. Why dual afms? well because if they both register half the air and they are hooked up in parralell they will send an average voltage that the computer should read as half the airflow that it expects, then mutiply the k value by 2 and it should be able to flow 600 hp i think. maybe i'm wrong but it works in my head so far. It was a cheap alternative to a single z32 maf and that's really about it. The z32 guys do it occasionally so i figured why not on the z31? And as for what ecu -- the stock ecu and a romulator which has been causing me major issues that hopefully i can resolve soon. (btw -- i've been running on one intake and one maf for initial tuning)1985 NA2T * 1988 SS * 1984 AE x2 * 2006 350Z -- irc.dal.net #300ZX
21C2E59531C8710156D34A3C30AC81D5 || ...-- ----- ----- --.. -..-
actually the second maf has a 2.5" intake so that if i want i can go with a bypass system instead and restore the original k value and it will run as normal... and there was some talk on one of the z32 sights about running dual mafs infact go here http://ztechz.net/id10.html and go halfway down and there is mention of doing this to a z32. As for somebody else having these pictures on their site it's possible that they found the pictures here -- http://forums.celicasupra.com/showthread.php?t=21887. And who is Jukka? I can't find him on this site... Man.. I have absolutely no reason to lie about what i do... in fact right now.. I can't get the bloody car to run -- the only way the bloody thing will run at all right now is with the k-value set to 0040 when (with 420cc injectors) it should be at least 0120-0150 (all hex values) And I can't figure out the problem..
On a more positive note -- as for the question of wether it is only a drag car -- pretty much. The owner of the car is a hardcore race fan and mainly wants it for drag racing -- i'm sure it will be driven a fair amount in town though and since we live in the city with the most sunshine in canada per year, it shouldn't be much of a problem. However, there is one other thing that might be very interesting to see -- if it is run in light rain i suspect the added water will heavily reduce intake temperatures (water injection i realize is a calculated amount) and thus not hurt the motor anyhow.8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
just so you know driving in rain with those scoops will probably soak the filters and either cause suffocating or sucking in large globs of water, which unlike sucking in water mist can be harmful
as for the dual afm, I don't see why you'd need to average the output
as I'm sure you're read, the afm at idle is between 1 and 2volts, the ecu is limited to read something like 5volts so even if the afm can meter higher like 6volts the ecu will consider it the peak value.... so the ideal isn't the half the voltage but rather to drop it so that your target airflow will be reachable at a voltage below the ecu's cutoff...
dropping the stock afm voltage by say 1volt via circuitry is one way.... or bypassing about that much air with a tiny tube from the second filter rather than full diameter piping, such as a 1" pipe
voltage in parralell does not change.. two 1 volt signals equal 1 volt... so if both afm's would normally read 1 volt (given that they were alone with no bypass) they will (assuming linearity) read 0.5 volts each... which will send a message to the computer of 0.5 volts... i may have to change the afm map to adjust for the voltage being halfed as it is not linear... it appears to be quadratic... so... i'll have to work out the math in the map. It may be possible to just use the z32 maf and map for it.... i'm just giving this a shot. Who knows what will happen... I don't expect the rain will completely clog off the intakes, but i'm not really concerned about that anyway as you know with this area being very low on rain. we have cacti, rattlesnakes, tarantulas, scorpions etc... very very dry here. I do appreciate the idea that it may plug off the filters... it's entirely possible... i hope it doesn't but if it does, oh well, lesson learned. This really is a drag car mainly, the guy is obsessed with racing... i just wish i could get the bloody engine running... going to see if my buddy still has r201 and replace all the resistors after i check the fpr and afm's. Thankyou very much for the suggestions.8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
http://www.vgpowered.com
wait a minute, you're running a stock AFM on cut-out resistors? Yeah, that won't work, unless you make a 2v drop on the AFM signal wire...
let me guess, the car would start, but would just SPEW out gasy smelling black smoke?vg33et -blew some chunks outta it, then gave it all away.
2009 370z touring/nav/sports
lol! yeah... i tried everything to get that bloody thing to work... but i've got a z32 maf on it's way right now, should be here this week i hope. It was actually worse than spewing black smoke -- it would generally not even start. The bright side of the situation is that i have learned how to change the spark plugs very efficiently without taking off the intake plenum.8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
the z32 should work, AND meter up to 500hp ;D
you'll just have to do a bit of work to get it running 'right'.
going to adapt the dual filters into feeding a single maf? or just going to work out the unmetered flow? 1000hp capability sounds just crazy ;Dvg33et -blew some chunks outta it, then gave it all away.
Twin into one intake for now -- one maf.. but it would be easily adaptable to have a bypass.... not sure what to do for he moment -- might even plug one of the intakes for the time being. As for the spark plug tool?? there is such a thing? I'm just using a plug wrench on a ratchet... The real pain in the ass is removing the plug wires.. I had understood that the book time on plug changes for that motor is like 5 hours or something stupid -- because they said you had to remove the upper intake plunum and intake piping to do it.8.5 custom arias pistons (.020 over)
eagle rods
mild port/polish
3 angle valve job
rad moved back
romulator
420cc injectors
