Well I just swapped in a new dash. The Dash I had was cracking so I swapped in a good one, the problem is my car had a digital dash and the dash I put in is analog. Everything works except my speedometer. The car is an 84 NA, the dash is out of a 87 NA, and the trannsmission is a T5. I was thinking possibly the speed sensor needs to be changed to the newer style? I really dont know, any help would be greatly appreciated...
Speedometer Issue
Well I just looked at my speedometer sensor, its a cable sensor. I tried replacing it with one of the electric sensors I have, it bolts into the transmission but I can not find a connector for it. Any help?????" I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
RedBeauty84ZX wrote: Well I just looked at my speedometer sensor, its a cable sensor. I tried replacing it with one of the electric sensors I have, it bolts into the transmission but I can not find a connector for it. Any help?????
I still have not figured out my speedometer issue. Anyone who has swapped 87+ analog gauges into their digital dash car please let me know how you wired it..." I don't want to come off sounding butt-hurt, but I really loathe most cressida owners and I'm glad I soiled their platform with a Nissan dinosaur under the hood." - Butter
zmech wrote: If the 87 is the electrical analog speedo then it is very easy to wire up. Get the 87-89 analog speed sender off the transmission. Pull the cable out of the speedo gear on your transmission. Place the sender on your speedo gear on your transmission. This sender creates an AC signal that is frequency proportional to the speed that it is rotated. So you take the two wires from the sender and attach it to where the speed sender is supposed to go on the gage panel.
I do not have my manuals here at work or I would tell you what pins to attach to. If you need that info, just PM me and I will get it for you after I get home.. If you don't mind getting me the info for the pins when you get home that would be great.
