e-fans draw lots of ampage, so if you have stock alternator, it's time to swap to a maxima alternator.
I personally use Flex-a-lite's 150, which draws 13.9amp and pulls 2800cfm, very beefy. It's all pre-wired with a built-in adjustable thermo switch, and it worked fine with my stock alternator for a while. One downside: it doesn't cover the whole radiator surface. But if it works fine with 100F days here in TX, I am sure it will be fine for you in Cali.
