update... the rears fit perfectly into the wheel well, with no rubbing on the sides and fill out the wheel well nicely ... the fronts, well, is another story. They rub on the "bridge" part of the brake calipers, not the actual part that clamps down on the brake shoes. I have 88-89T brakes up front, so I don't know if it makes a difference, but I have had to grind down the surface of the "bridge" a bit to make the rim fit without rubbing. But other than that, the fronts fill out the wheel well nicely, no battleship. I will have pictures as soon as I grind down the other caliper and get the wheel on.
Conquest TSI wheels?
Brian,
I can help you strip off the clear coat and repolish those wheels. We may be able to smooth out some of that curb rash also. I did my wheels and it was an ass load of work but the end result were well worth it. Let me know.
Also, I gave those CDs from the Auto-X to Kyle. You can get a copy from him.
Here they are,
Fronts 16x7 205/55R16
Rears 16x8 225/50R16
Now I just need to find some center caps ... or make the Z ones fit.[strike:ff0tp92h]1984 300ZXT[/strike:ff0tp92h]
2000 Porsche Boxster
2007 Toyota Yaris
craZed wrote: They look good on her. 8)
How do they feel weight wise?[strike:ff0tp92h]1984 300ZXT[/strike:ff0tp92h]
2007 Toyota Yaris
i just picked up another set of Conquest rims for $50, 16x7 and 16x8.
Jezz, i have too many wheels lying around now[strike:ff0tp92h]1984 300ZXT[/strike:ff0tp92h]
2007 Toyota Yaris
