Spec-v rims rubbing up front
  • Spec-v rims rubbing up front
    hi i have an 84 n/a 300zx which seems to be rubbing the struts up front
    i was wondering if anyone has tried these rims before.
    what do you recommend spacers?
    if so where should i get some, and will this change the handling characteristics do to the fact that only the fronts rub or should i do all 4
    ty for the help i just got this car last week so i have a bit to learn
    DD:
    86 Black Turbo 5spd
    The Fallen:
    Parting Currently:
    Garage Sale
    axe yoursef this questions:
    do you like being rubbed? yes/no
    do you think rubbing is good? yes/no
    do you need pictures of centerfolds for rubbing? yes/no
    how much do they rub? ______
    what size spacer will fix it? ______
    are you too poor to buy 4 spacers? yes/no
    etc....
    if you want me to think for you I charge 2.99$ a minute, 10 minute minimum, which is in line with most psychics
      No spacers over 3mm. Measure distance from wheel to inside of fender flare straight out, then add a wheel adapter about the size.
        your problem is you are running Spec-V rims, on a RWD car.
        FWD offset = no bueno
          i'll sell my 350z rims
            Spanish??
            84' 300ZX 2+2 NA (Hardtop)
              hey, i was wondering if anyone knows what the nismo wheel studs are made of? chromoly? or are they just longer?
              I' m getting a local machine shop to whip me up a set of wheel adapters for the rims and i have like 6 studs that are stripped. im planning on just swapping out all the studs.
              My options seem a little limited. I can get stock from the dealership for 8 bucks a pop, nismo 50/60mm for like 8 bucks from courtsey nissan, or gp sport chromoly for like 45. Is there any other options im missing?
              ty in advance
              DD:
              86 Black Turbo 5spd
              The Fallen:
              Parting Currently:
              Garage Sale
                well if you get the cromoly ones make sure they are the same thread/pitch (m12x1.25)
                but when was the last time you heard anyone breaking a wheel stud? so as long as you avoid chinese garbage and get nismo/arp/.... you shouldn't have any problems
                  G-E wrote: well if you get the cromoly ones make sure they are the same thread/pitch (m12x1.25)
                  Do you know the arp part number? I took a look at their online catalog and i didnt see anything specific to the z. i would perfer them over other companies.
                  DD:
                  86 Black Turbo 5spd
                  The Fallen:
                  Parting Currently:
                  Garage Sale
