Ok ive tried to get answers and im going to now try this board as my last hope. For about a year my cd player, amp and all have been working fine with no hiccups. One day things just start going crazy and now when i turn off my car, the antenna stays up, and the amp stays on. its been killing my battery if i let it sit a few days. I tried putting another cd player in there and the same thing happens. Ive tried everything from leaving the speakers disconnected from the cd player, leaving just the antenna plugged, leaving just the amp plugged, and nothign seemed to change the problem. Something else that is strange is that the rear driver speaker is grounded when plugged in. I dont know why its the only speaker that gets grounded when its hooked up so i unhooked it from the cd player. Problem still persists. Im not sure whats going on but how does it screw up after being fine for over a year? Anyway it has to be grounding but i've no idea where it could possibly be. again, my symptoms are- rear driver speaker grounding out, antenna does not shut off, and amp does not cut off. One more note, i noticed when i removed the cd player the heatsink was warm to touch and it hadnt even been on. Someone has to know whats going on, i dont want to pay loads of money for someone to look at it when its probally something so simple.
thanks for the help, much apprecicated.
