For paint I'm using Rust'O'Leum oil based paint.
To apply the paint I'm using a high density foam roller for the big areas, a foam brush for the hard to reach areas, and LOTs of paint thinner and mineral spirits to thin the paint out to the consistency of a little thicker than water.
For the sanding department, I'm using 500 to 800 grit sanding in between coats, 1500 to 2000 grit for final sanding, and then polishing compound to finish it off. Have to wait a month for the paint to dry rock hard before I can apply the wax.
I've been also considering the applying the oil-based clear coat available from Rust'0'Leum to bring out even more of the "bling"
passenger fender drying in the sun
passenger door ... done
Ok, I've got the lower black portion done, now it's on to the upper silver part.
Upside:
Cheap ~$50 from start to finish. Plus, I'm removing all the trim in order to make the paint job look seemless.
Downside:
LOTS, LOTS, and LOTS of patience, sanding, painting. Each coat takes 24 hours to dry. Should take a total of two months to finish.
Upside:
Downside:
