Digital Dash Color Change
  • Digital Dash Color Change
    i was wondering if there was any way to change the color of the green backlights on the digital dash (tach portion, etc.)?? any help appreciated, thanks.
    1984 2+2 Conv. to Turbo
    Stock Motor w/T3 @ 9.5 psi of boost, raised fuel pressure 7 psi over stock, a tiny bit of timing advancement on the distributor and shorty intake and exhaust.
    As far as I know there isn't away and even if there was it would probably be a major pain in the but to change the colors of the bars I'm thinking of changing my digital to analog
      mike1988 wrote: As far as I know there isn't away and even if there was it would probably be a major pain in the but to change the colors of the bars I'm thinking of changing my digital to analog
      Confucius say: Man who steps in barbecue sauce, will eventually put his foot in his mouth.
      Yes it is possible
      Yes it is easy.
      Standard Green Dash Display:
      Removal of trim ring, acrylic shields, backround plate and green filters. (easier with steering wheel removed)
      Measure filters and make a prinatble template in ms visio. Printed on overhead projector transparancy.
      Cut out colored pieces and tape into place.
      note:
      Its a better idea to use parcan gels, used in stage lighting. They are heat resistant and do not fade much over time.
      The filter i printed on an inkjet printer has faded and the blue is not as dark anymore.
      The rest of the displays (clilmate, radio, center cluster) i have not done yet. Climate control uses green LEDs behind the buttons
      and standard bulbs with the green condoms for the LCD display. The stock radio has green filters in the buttons and condoms for
      the LCD display (if i remember correctly
      ). I have not dug into the center cluster yet but its probobly the standard bulbs with the green condoms.
        well guess I was wrong I was thinking that the gauges were done a different way I haven't had a chance to play around with the dash that much yet.
          Wow that looks quite good Z_Karma, I'm impressed! Although is it a little blurry or is that just the photo? Maybe something slightly more transparent to get it clearer?
          http://youtube.com/c/zcartube
            mike1988 wrote: well guess I was wrong I was thinking that the gauges were done a different way I haven't had a chance to play around with the dash that much yet.
            ....Although is it a little blurry or is that just the photo? Maybe something slightly more transparent to get it clearer?
            some of the blurriness is my camera, but the transparency does have a texture to accept the inkjet ink. Colored gels would be much better.
              badass! i REALLY appreciate the help guys, i really like how i can go to this forum for anything i need!
                also
                http://www.300zxrestoration.com/lighting_color.html
                  I am in love with the blue!
                  I've been wanting to do that.
                  Awesome info guys.
                  Drive
                  1975 Datsun 280Z
                  1988 300ZX (NAtoT soon)
                  2006 Kawasaki ZX6R
                    yeah, i'm really glad i brought it up and someone was able to show how it's done. i think it's a neat and quick mod that requires hardly any $$$$ spending at all, and had GREAT results! great work guys!
                      in a gel that looks to be a 15 blue, but it's not the same blue tone
                        On 300zxrestoration.com it says he was unable to find the appropriate sized gel caps for the bulbs? I dont know what's with the purple on his site either?
                          [quote]Z_Karma wrote:
                          *snip snip*
                          note:
                          the LCD display (if i remember correctly). I have not dug into the center cluster yet but its probobly the standard bulbs with the green condoms.
                          mmmmmmmmm barbecue
                          Here are some links for you, if it suits the board. I did this with my center consul and used the same technique on clear acrylic sheets for the dash. I have since reverted it all back to green. Funny how once I am finally given the choice of colors, I actually liked the stock green!
                          here's a good link for the gels
                          http://z31.com/board/read.php?id=65308&srf=nyet
                          http://www.vgpowered.com
                            Thats the most BALLA sH iT eva....
                              I'm gonna stick this picture in the sticky too.
