okay a little help
  • okay a little help
    what parts of the Z32 bolt into the Z31.
    i was thinking the Turbo Shifter will work in a Z31 turbo. like B&M racing
    how about the seats?
    is the steering wheel spline and diameter the same????
    thanks
    the sierra club is gay!!!
    84z31 wrote: what parts of the Z32 bolt into the Z31.
    thanks
    The transmissions are basically identical on the Z32 whether TT or NA.
    Shifter will not fit.
    Seats can fit with some custom work with the rails.
    Steering wheel SHOULD slide over the splines.
    Things you missed:
    The complete rear subframe CAN be swapped. Again, a little custom work. Check the specific thread for more information.
    Z32 wheels. (small spacers required)
    The tension rod style is the same as the late 87+ turbo. However, it doesn't mount the same.
    Fuel filter.
    Brake Calipers.
    Fuel pump.
    Pistons and rods. I think crank as well.
    I'll think of more later on.
    545 RWHP & 540 RWTQ
      thanks.
      i know of a few Z32s in salt lake. maybe seats.
      how about 240sx???
        84z31 wrote: thanks.
        how about 240sx???
        Steering wheel fits the same.
        The 5 speed is the FS5W71C.
        Bolt pattern is the same as 84-85 NA Z31's.
        Of course the throttle body swaps over.
        I'm sure there a couple things that could be useful.
        545 RWHP & 540 RWTQ
          does the rear diff bolt in??
          then i coult just get the driveshaft resized. i found a VSLD :!:
            [quote]FlawleZ wrote:
            Originally posted by 84z31
            thanks.
            how about 240sx???
            What bolt pattern?
              bah nevermind
                [quote]Lance wrote: [quote=FlawleZ]
                thanks.
                how about 240sx???
                What bolt pattern?
                I'm sorry. It was totally in my head what I was implying.
                The wheel
                bolt pattern is the same and the wheels are interchangeable.
                545 RWHP & 540 RWTQ
                  no a 240sx rear differential wont bolt in. Only thing you can do considering the 300zx and 240sx diffs are both R200's is swap the VLS differential itself and picion from the 240sx into the 300zx housing, and you would need to run 88ss axles which cost shitloads. The 240zx diff housing has different mounting points than the 300zx, this is why. Also many infinities have R200 diff internals that will swap over, i think the J30 and some others do....
                    which j30s have vslds?
                      roastin300 wrote: no a 240sx rear differential wont bolt in. Only thing you can do considering the 300zx and 240sx diffs are both R200's is swap the VLS differential itself and picion from the 240sx into the 300zx housing, and you would need to run 88ss axles which cost shitloads. The 240zx diff housing has different mounting points than the 300zx, this is why. Also many infinities have R200 diff internals that will swap over, i think the J30 and some others do....
                      Who said a 240SX Differential WOULD bolt in?
                      545 RWHP & 540 RWTQ
                        84z31 asked that dude....
                          MrwassmanNA2T wrote: 84z31 asked that dude....
                          Oh I totally missed that. :shock:
                          545 RWHP & 540 RWTQ
                          • #14
                            haha, wish i had magic unversal diff powers.
                            • #15
                              MrwassmanNA2T wrote: haha, wish i had magic unversal diff powers.
                              It's called a live axle and ford 9 inch. That's as universal as you can get, and there's 4324585298475 LSD options.
