OK, here is the story. Car is a 84T with digital dash originally.
I have a 87N/A analog cluster and dash harness. I plugged it in and the lights on the analog cluster come on. Next thing is i got a 86N/A analog HVAC control and the harness from it to the inside of the dash. The harness on the 84T body plugs into the 86N/A HVAC control but is much much different having many other plugs and does not power the thing up. I cant swap the 86N/A HVAC harness because all the plugs are different. So....my question is:
Should i get another 84T HVAC unit to plug into the stock wiring harness to control the heater and A/C? If it was digital originally, do i HAVE to get a 84T digital HVAC unit or can i get an analog unit? are all the plugs the same between the digital and analog HVAC on the 84T?
Also i plug in the analog cluster and dash harness and controls next to steering wheel.....all the controls next to steering wheel like hazards and stuff do not work????
Another interesting thing to note is the 87N/A wiper/headlight switches plug right into the 84T harness and work identically as the 84T so i dont need them like i thought, i can bring them back to the junkyard....
