I'm confused on what needs to be done about the pilot bushing, and mounting the flywheel.
Crankshaft of motor originally manual trans
Crankshaft of auto
So if I understand this correctly, I need to remove the marked peice (or drill out with a 13/16th bit) to clear the input shaft of the manual trans (also marked).
The bushing/bearing next to the clutch fork on the input shaft is the throw out bearing correct? Where is the pilot bushing?
I guess I'm confused on how things are "supposed" to be...and how I'm gonna get that ring out of the crankshaft.
Crankshaft of auto
