Talk about a fast turnaround. These guys built me a custom clutch and got it to my door in a little over 48 hours. I'm told I will be completely satisfied with it, and if not to simply give them a call.
SBC's own sintered iron full face "FE" series 240mm disc with sprung hub (250mm will be available in a month or so)
"SS" series modified pressure plate.
650+lb/ft torque capacity (250mm disc should be over 700 with same clamp load)
Pedal should be about like a ACT HD pressure plate.
New lining for the fidanza flywheel in there too.
It came with everything a clutch kit should; a quality koyo throwout bearing, alignment tool, pilot bushing.
Supposedly this should outclass every other single disc clutch on the market, yet still be street drivable, have three times or more the lifespan of a copper-ceramic 6 puck, more torque capacity and better engagement. I'll be finding out if this is all true. I hope to have time to install it in the next couple weeks.
I will be giving this thing a complete and thorough review as I beat the snot out of it. If it's everything they say it is, I will be recommending them in the future.
