Launching.
  • Launching.
    2 questions
    1) what RPM are you guys launching your cars at
    2) do i need to worry about breaking stuff with a stock motor
    i currently have a fidanza flywheel, act street clutch, aka indestructible, and basically its a NA2T, so NA half shafts.sometimes when i launch it i get bad wheel hop!im afraid to break something, but ive seen my friend drop the clutch a million times in his 50th.
    http://www.youtube.com/user/onefast87
    you can control your wheel hop with better shocks and springs.
    key word: stiffer :!:
    the sierra club is gay!!!
      Launched at a variable RPM. Kind of pulsate the gas between 2700-3400 to build some boost.
        i went out and launched mine pretty hard tonight to make sure my alternator belt wasn't going to fly off. i had some pretty hard wheel hop as well. so it looks like i'll be getting some tokicos for the rear with the adjustable.
          If you want to do a good launch dont just drop the clutch. You have to slip it very quickly, taking a total of about 1 second. to where it just starts to grab(you can feel it) and 1 second later, totaly released.
          This is hard on your clutch however. I run a six puc ductile iron disk and lauch at 20psi at 4700 -5000 rpm slipping for about 1 second.
          Hopfully your clutch is as indestructable as is "known"
          This info changes greatly if you are running street tires and not slicks
            ^ the same idea applys. Street or slicks.
            You cant just litterly rev, drop the clutch and not expect things to shimmy, shudder shake and hop a bit.
            A quick clutch release is fine but the old foot slip and sudden engagement isn't going to work well in most cases. A bit of slippage and grab will be best if your clutch can stand the forces over time. On the other hand rev and foot slip will cause more damage to parts than a bit of slipping of the clutch.
            I lit up my NA on some gnarly ass rough pavement with virtually no wheel hop and both sides laying down equal length marks. Same on very smooth and even pavement.
            Performance costs money.
              I wouldn't call it indestructable. Take a look at the one I pulled out of a bone-stock SS with shitty winter tires on the rear...
              It was pretty well nuked.
                Az4u2c wrote: I wouldn't call it indestructable. Take a look at the one I pulled out of a bone-stock SS with shitty winter tires on the rear.
                ok my bad hear guys when i say "indestructible" i mean to say the FS5R30A transmission.
                  OR-Zman wrote: ^ the same idea applys. Street or slicks.
                  Oh I meant that it changes greatly meaning launching at 20psi on slicks or street tires. Basically meaning if you try to launch at 20psi in street tires then your are gonna get nothing but wheel spin and smoke.
                    ^I was actually agreeing with you. Perhaps I wasnt quite clear on that though. :wink:
